TwinTurbo.NET: Nissan 300ZX forum - Startup Squeal
Startup Squeal
MyDreamZ
on March 22, 2010 at 11:39 PM
On start-up I have a loud squeak/belt squeak I'm assuming? Is this more than likely the tensioner assembly going bad or is there something else I could check b/f spending money?
Startup Squeal -
MyDreamZ
23:39:38 03/22/10
Alternator belt? (n/m)
cHiNgLeZ
01:49:57 03/23/10
It's a belt. Check power steering. It's gotta be tight. (n/m)
zellamay
02:00:42 03/23/10
How old are these belts? Milage? (n/m)
draker
03:51:39 03/23/10
Most likely alternator then PS. To check spray WD 40>>
ZUL8TR
05:43:22 03/23/10
Thanks for the tips, this
MyDreamZ
09:57:09 03/23/10
Sometimes the belts just dry out especially the edges >>>
ZUL8TR
15:31:52 03/23/10
Re: Sometimes the belts just dry out especially the edges >>>
jaidieray
18:48:47 03/23/10
That's a possibility and easy to determine. (n/m)
ZUL8TR
08:34:32 03/24/10
PS line leaking fluid onto alternator belt. (n/m)
ChristopherTheOne
21:52:31 03/23/10
same here
gbeto
16:23:19 03/24/10
